It will soon settle down mate and run ok.@t-tony, does the airflow sensor adjust the mix accordingly as I assume that the new filter will allow more airflow.
Just browsing the local autobarn and came across these £37 english.fit 3.3.5.and 4inch maf so should fit the z4 ?cant remember the maf size. Thinking of buying one waddu u think. Not sure of uk prices ?Mega fail today, we ended up going over to Gaz's in Shirl's Eos so haven't got to road test the induction. Sounds very nice stationary when you press the loud pedal, will have to wait till tomorrow now.
@MAURICE THE MARTIAN this is a Ramair Universal induction with 90mm OD, I bought it on Black Friday on Best Offer, I offered £10 less than asking price and got it for that. The silicon connector was £7.00 and came with the Jubilee clips.
That's a shame mate but easy enough to get it changed, just means a delay. But you don't want to be reducing the intake dia. or it'll defeat the object.Had some time today so decided to fit the Induction kit, the wife got me one for an E36 but its way to small, my MAF is 80mm but the new filter is only 65mm, I could have messed about with varying bits of pipe and hose clips but decided to return it and get one the right size.
Not really how air works. Unless you have a sealed box and direct feed. All the open ended ones give you is slightly more surface area, you are still drawing most of the air in from the sidesI paid £47 for the filter and sleeve mate and the MAF dia. is 90mm. Not sure how the Aussie dollar compares? That filter has a blank end and takes air from the sides so would get warmer air I think, mine gets direct feed from the cold air inlet straight into the front end of the filter.HTH.
I agree you are still getting some from round the side Tim, but with open end right against the cold air feed it will be getting a fair amount forced straight into the "filter" , there's no way it can't be.Not really how air works. Unless you have a sealed box and direct feed. All the open ended ones give you is slightly more surface area, you are still drawing most of the air in from the sides
Wasted.Well i just invested £37.
Or wasted .time will tell
Hi mate, were those covers on the strut tops a standard fitment on your car, mine doesn't have them? Had an idea for some under bonnet bling too. Will post up some pics when I get it done, just need some warmer weather.Sounds gud mr T .
Fitted mine yesterday deffo more induction noise that combined with my partial back box by pass sounds great.
Getting a new o2 sensor fitted on tues so i'll be able to compare mpg.View attachment 48533
