I'm going through the process, as no doubt many other have. of replacing and rebushing the rear trailing arms. All is going well on removal, I've successfully disconnected and removed everything except the 2 bolts each side that bolt the trailing arm to the cross beam each side. What's the trick in undoing, and removing these 2 bolts. The access and area seems impossible! Really appreciate some tips before the Zed finds itself in the bin! Thanks guys, and merry xmas and hny!
