Looking good.
I opted for using the old door mirror wiring for the window switches. In the course of a build, I seem to have the doors on and off quite a few times. I also remove the doors and the door skins for painting. Again I fit the door skins with rivnuts so they can be removed, bonding the skins on is not a good idea for future maintenance. I also removed the door to fit the new door liners, I used hidden Xmas tree plugs which are hidden as on modern cars rather than visible mounting screws. This is a lot trickier and no room for error, it is much easier doing it with the door on a bench. Of course, the original cars did have visible screws............so cheaply made!
With the rotary window switches, I pack the MGB window winder with GRP paste and push the rotary knob into the centre, make sure the screw hole in the window winder is kept free and watch out the GRP paste that is expelled around the edge, it gets everywhere.
The GRO paste is not to glue the knob on but it stops it from turning within the winder.
You then need to drill through the window winder hole, push the rotary knob and winder back onto the switch. The grip isn't enough to hold the winder in position except for straight down. A self-tapping screw through the winder and hole you have drilled will expand the fitting in the rotary switch a bit like a Rawl plug, this is enough to hold the winder in the desired position.
