How To Guide Z4 roof motor relocation to boot
ptas
Yes brake lights work.... i also tested the rear boot motor by taking leads off and hooking directly to battery and it spins fine
So i have blinking red light and when down and up pressed no action at either the upper latching or boot motor.
Something preventing it from sending power to both motors.
Tx
bcolins
Well, my missus's Z4 succumbed to the renowned roof motor failure last week.
Windows drop, roof unlatches then nothing.
So I set about a repair and decided to photograph what I did to get it, not only working, but relocated as well.
The main problem with the Z4 roof motor is its location.
The motor, surrounded by some sound proofing foam, sits in its own small black plastic housing,
This housing is tie-wrapped into a plastic moulded compartment just behind the L/H door (UK passenger side)
There is a drain hole in the bottom of the compartment, which can become blocked. The compartment will eventually fill with water, from rain and/or washing. and the water then spills into the motor housing.
The problem is this.
Imagine you have a bucket with a drain hole, (that is the plastic compartment behind the door).
Put a cup inside your nice dry bucket, (the cup is the motor housing)
Now put a motor into the cup
If you now plug the drain hole and start filling the bucket with water, eventually the level reaches the top of the cup, and the cup also fills with water.
Now unblock your drain hole and the bucket empties, but the cup does not.
No amount of further unblocking and keeping the drain hole clear will empty the cup, and that is exactly what happens to the Z4 motor, as it sits and slowly rusts away whilst remaining submerged. And it only has to fill once.
So here is the (second) way I did it: (other methods are available.... =)))
I know! I removed a roof once to do this on a previous Z4.
First job is to remove the parcel shelf.
To do this, squeeze together and push upwards the plastic clips. There are two on each side of the parcel shelf:
The clips will probably fall down the sides, but you can get them later,
Pull the fabric flap off the shelf:
Now pull each hinge upper plate away from the parcel shelf towards the centre of the boot:
this is best done with the parcel shelf in the upper position
Remove the parcel shelf by moving it towards the drivers side as far as it can go, and pulling the other end out. Then you can rescue any clips that you pinged off earlier.
Now you can remove the complete LHS hinge assembly for the parcel shelf.
Remove the Torx bolt at the front, and the bolt at the back.
There is also a rivet, in the now viewable plastic well.
Pull the centre of the rivet out with some pliers, and then remove the outer washer:
Now give the whole hinge assembly a good pull towards the middle of the car to remove it. A little hump shape underneath it provides some resistance, but otherwise it just needs a bit of effort.
Now you can see all the way into the well and behind the door latch is the dreaded motor in its housing:
cut the tie wraps to release the hoses
By lying on my back in the boot with both arms above my head and through into the compartment I was able to wiggle the housing about.
It is held in place by two tie wraps around the ram which is nearest the door, and on the RHS of the housing. But I could not get it to shift. I even tried from the door end but that was worse and just wasted time taking off the plastic cover and speaker compartments behind the seat. None of that is needed by the way, Everything can be done from the boot.
So what I eventually ended up doing was separating the motor housing,
The housing comes in two parts (see later photo's). It is held together with some black fabric tape.
I was able to pick at the tape and pull a lot of it off. Then with a long bar I was able to separate the top of the housing from the tie wrapped bottom section exposing the pump.
From then on I could pull out the pump/motor assembly, and finally wrench the bottom of the housing out.
The motor was soaked and rusty,
and the bottom housing was full of the dirtiest water imaginable, that could run down my face as I tipped it up in the boot over myself.....!
With the motor pulled into the boot you can see the ram and associated hoses to it, Try not to pull too hard on these:
Now you can see (with a camera) the bottom of the plastic well and the drain hole. Note the rusty water tide mark:
The housing looks as follows, with the tiewraps on the plastic fin which breaks away eventually:
You can see the remainder of the fabric tape that I couldnt get too
and inside is the sound proofing which stays soaked:
You can separate the motor from the pump by removing 2 allen bolts, but do this with the pump downwards and break the joint nearest the motor or you will lose hydraulic oil (ask me how I know)
With a quick wipe down and wire brush, I then sprayed WD40 all over it and inside it. then connected to a 12v power supply and it immediately came back to life so I ran it in both directions whilst still oiling it.
Sorry no pictures for that.
After putting it back together and topping up with hydraulic jack oil through the little plug in the top of the pump. (check level with roof down) I was able to get the roof up and down fully with no noises,
To operate the roof you have to temporarily press in the parcelshelf position microswitch (i used a 12mm socket for that):
The hoses that now go to the motor have to be routed across the plastic well and below the hinge. This involved cutting the plastic away and securing as follows:
The hinge assembly had to have the same treatment before being refitted:
Then time to rebuild:
I pulled out the LHS carpet from the side of the boot to be able to locate the motor.
I tiewrapped the dried out soundproofing around the motor and tied it to a little connector block which is under the LHS side carpet:
Keeping the motor underneath and the pump uppermost:
Then just wrap the carpet back around,
refit the parcel shelf and fiddly clips, and finally the fabric flap.
and most importantly have a beer, knowing that it will no longer get wet, It is easy to get to, and top up if required.
Over 2 grand to fix from BMW,
I did it for free.
Thanks for taking the time to not only report on how you did this, but to also take excellent instructive pictures. I am stuck,.....I have the motor and pump assembly lifted out of the bucket,......but it is being held in place by something,....I believe it is the hydraulic lines,....they appear to go back down into the bucket and disappear somewhere,......preventing the motor/pump assembly from being pulled into the boot area.
Suggestions?
Brian
Not sure what it could be, but, it isn't the hydraulic lines. It has to be something else.
colb
Newport, South Wales,UK
The lines do indeed go under the bucket and the bucket needs to be lifted upwards bringing the lines up with bucket so they can be unclipped from the guides moulded in the bucket base. The tie wrap holding the bucket in there needs to be cut or broken so the bucket can be lifted out.
bcolins
Got it out,….heres how. I happened to catch a post referencing removing the rubber at convertible top hinge point on the passenger/left side of the car and using a long knife or in my case a long prybar, breaking the plastic bucket attachment away. Get a good flashlight/torch and look in there and you’ll see where the bucket is attached. With some serious prying with a
24 inch prybar I was able to break that attachment and then got back in the trunk and was able to now lift the pump assembly further up and then reach further back in and grab the bucket and pull it up as well. Once the bucket was out of the well area, I could see where the zip tie/tie wrap secured the bucket to the hydraulic lines and was able to reach back in with a sharp knife and cut that now I could pull the pump into the trunk and completely remove the bucket assembly.
bcolins
I just scored this hydraulic pump assembly out of a 2009 Mustang convertible at a local wrecking yard for $20 and picked up a
needed shift knob for four.
colb
Exactly the same way I relocated mine using a long metal rod to lever the housing up and out after spiking the bar through the lid joint, Used some wood blocks in the boot to provide a fulcrum pout to lever it up. Mine had been replaced before and whoever put it back used more than one tie wrap to hold it in. My motor was pristine and will remain so now it’s in the boot. Just remember to check the drains don’t get blocked in the future if they do and fill up it will overflow and drop down on the airbag satellite modules at the base of the door B posts killing them.
