I am.......’cos I just got the thing unseized and apart
Rusty bits of metal. 0 - 1 Bognor Lean-to ...........
Malc, I can’t thank you enough you went above and beyond. Your patience, skill and knowledge was epic! I am greatly in your debt. Thanks again and all the best NickNot a lot done on my project today, other than I snapped the rusty horn brackets off to bin both horns.....( Andy.....more bits for the list )
The whole plug connector snapped off!!!!!
Then had a visit from New member Nick ( @Nickskip ) with a view to sorting out a stuck drivers seat......
Two and half hours it took to finally get the seat out of the car......rear bolts just visible......and the front nuts visible doing a head stand in the drivers footwell
I ended up grinding down an old imperial spanner to get access to the 13mm nuts and could move them a fraction at a time then turn the spanner round.....but, eventually the seat was out ......
Using my 2.8 battery I could move the seat on one side to get access to the T45 screw, took it out and pulled the rod out. Needs a clean but ok to reuse......the other side , could not move it and only access to the T45 was through the rear bolt hole. .....but the head of the torx bolt is too big........so only thing to do was file it out just enough to allow the bolt through it. Only about 1mm so wont affect the fixing bolt.
Then with my usual engineering skill, I finally removed the shaft, with a bloody great hammer ( not really Nick)
The cause of everything is the block has seized to the shaft.......
Will try and free it off but may be better to replace....have to wait and see on that.....
But ......having no drivers seat means the car cant be driven........so I have two silver 1.9’s outside the house
Mmmmm.......wonder if I need any spares ?
At least putting it back in wont be as long........
I find the compressed air hit and miss. Usually okay for rears. More problems with front. Never know how to get best air seal. Biggest problem is I usually end up with brake fluid exploding in my face which is clearly a stupid thing.I use compressed air Malc, didn't know if you have a compressor or not.
