Well if this morning was not too good.....this afternoon was a disaster.....
Thought I would try to remove just one of the studs to see how long it would take.......that was my first mistake!!!!!
Ground the remains of the stud close to the exhaust flange and centre punched and centre drilled it to get a start.
Then stating with a 3mm drill commenced drilling it out....Definitely need sharp drills , and I might have to get a sharpening jig to save buying lots of new drills. The studs are rock hard.....
But, bit by bit, I started to get through it gradually deepening and widening the hole getting closer to the diamter of the stud hole in the flange....one more drill should do it.........BUT NOT IF IT BREAKS IN THE HOLE........the recoil on the drill when it caught nearly broke my wrist.......
......... I did try whacking the stud with a drift to see if it would release, but no.
Absolutely no way to remove it......So plan B was devised.......
Take the manifolds off.......So read Bentleys......and I still cant fathom out why is says removed the washer bottle, which is on the other side of the car, up near the windscreen......Past caring by this point so out it came.....
Then it says ‘undo the manifold nuts’ ...two hours later , covered in crap, arms bleeding, I finally had the front 8 undone.
6 of The studs came out so I will get the other two out and replace them all, plus the gaskets.
So the front manifold was now loose....but can’t take it out as it still has a sensor screwed into it. The lead I assume unplugs some where....but at that point my LED light went off and needed to be recharged.
Can anyone tell me where the sensor wire unplugs from???
Once I can get it unplugged and out of the way I can then do the same again for the rear manifold.
Then I can work on them on the bench, which should be a lot easier than scurrying about underneath.
So for now.....Beers
, get something to eat
, and watch the first game of the Euros
and worry about all this tomorrow!!!!!
