This morning was an early start.... Tescos shopping at 6 am......nothing in fridge and no beers
Then a bit later on got out to the garage to start stripping more stuff off......
Front end ......why? ......... Because there’s nothing left of the back end to remove
Someone had had some of the bolts off as they were greased and came apart really easily......but others were more stubborn, but didint stand a chance against the ‘ super sockets’.........well, all except for a ABS sensor bolt...that decided to shear off
......another task to do!!!!
Right .....I have the tools, and a rough idea.....
Back plate is well shot as was the other side
But an hour later. ( or 10 minutes if Lee reads this)
The wish bone and track rod will be coming off later as I have replacements already.
Then on to the other side.....
A couple of things I did notice.....
The air intake was just dangling in mid air......?...
One of the bonnet catches is missing !!!!!!
The power steering loop is held one side by a cable tie
And found some nasty rust on the bonnet....both sides....
so easier to get a replacement bonnet at some stage
Hopefully Topaz blue ....but not a problem if not.
All this just so I can have one of these.......6 pot.....
But all this work today means I can take it all up to ZSHQ tomorrow.......and get the springs off, the hubs separated , and everything can then be shot blasted and powder coated with the trailing arm.
The missing parts from Sopers arrived this morning as promised, so all orders now complete.
Tomorrow is another early start .....but only as everyone meets at the breakfast stop first .......yummy.
, and will come home via Andy’s ( Spurs) to collect a few parts.....and probably order some more !!!!
