Finished working on the Beastie for tonight.
Finally got the bonnet fully in:
- Upper bonnet catch positioned, drilled, tapped and fitted
- Bonnet lower catch plate adjusted and bolted in place
- Windscreen wiper positions marked
- Rear of front clam bolted through bonnet catch plate - this helps set the height relative to the bonnet
- Bit of fence wire looped around the bonnet cable as a temporary emergency pull
- MGB seats stripped down to see what I need to order
All good sensible progress with no effing and blinding. Trouble is the whole front end needs to come off again to paint the bonnet bracket, fit wiper motor and operating cables, change ECU, add M54B30 manifold and oil catch can!!!!!!
Bonnet Fit
Pics 2-5 Pile of rust and foam - ehemmm I mean a pair of beautiful Fauxrarri seats!!!
Seat pads are OK, backs may need attention or replaced.
Card backs need replaced or repaired
Recliner levers are nice (need a polish)
Previous owner must have been sitting on the floor judging by the diaphragm!
Wiper and washer positions
Bonnet catch plate fixed in place
