MisterP007
Tunbridge Wells
Two lengths of Stainless steel angle arrived today:
2000mm long, 100 x 100 90 deg angle 1.2mm thick and very nice brushed surface. These are for use as sill covers.
The ebay seller had made a mistake on the listing and had 1500mm at £36 each, but 2000 lengths at only £6.30 each. I thought it had to be worth a try so I ordered two on overnight courier (to make sure they sent them before they noticed the price must be wrong).
RESULT: they arrived today £20 total inc delivery!
Just looked at the listing again and they are £46 each and probably still good value!
I need to do a bit of cutting and shutting to make it work properly but hey-ho!
MisterP007
Tunbridge Wells
Well, the £6.30 stainless steel now looks like this.
Got to make a blanking angle to seal the top of the cover sill at the front end.
jaguartvr
I think it looks better without the stainless, sorry. It almost looks as if the chassis is showing, with the existing BMW sills the lower section that shows is tapered which softens the look. Most people have just painted the exposed section black, I wonder how it would look if you stone chipped it and painted it in the body colour?
MisterP007
Tunbridge Wells
Hi Steve,
I know what you mean, it initially looks “heavy” like a big, fat RSJ. I think this will vanish when the car is painted, especially as the car colour is Silver.
jaguartvr
You could paint the top inch silver and leave the rest stainless, that I think would take the heavy look away.It's not as if it in line with your eyes unless you are on your knees
MisterP007
Tunbridge Wells
The plan is to fill the bottom of the GRP down to the correct curve which will reduce the stainless by another 1/2”. The SS part is then only about 1 1/2” tall, which on a bright silver car will not be heavy.
MisterP007
Tunbridge Wells
This evenings messing about:
  • formed some stainless steel capping for the gap in the top of the stainless steel sill cover. Bonded in place
  • Cut out the crack in the front GRP valance. Drilled out bonding holes
  • GRP matting applied behind the crack with an aluminium brace bonded in
  • And, in the last picture, made my interpretation of Starry Night by Van Gogh
MisterP007
Tunbridge Wells
Look what arrived today!
So tempting to start on the dash now but the outside is not done yet.
MisterP007
Tunbridge Wells
Car is still outside in the drive in the pouring rain so diverted to the workshop and made a start on restoring the seats.
Pingu
It looks like you are using a grinding disc. I'd recommend using a flap disc. It's just as effective at removing surface rust, but won't damage the seats as much - btw, your seats don't look damaged.
MisterP007
Tunbridge Wells
Hi @Pingu
The cutting disc was only there to cut the headrest brackets off. I cleaned the surface rust with 100 grit sandpaper by hand as I find it easier on intricate parts.
I have then thoroughly cleaned them with panel wipe allowed to dry and then rust treated with Bilt Hamber Hydrate 80.
I know what you mean about flap wheels though, very handy sometimes.
The seat frames are pretty much un damaged apart from having to re-seat one of the torsion springs for the reclining mechanism (god those things are strong, I needed to use a 2-foot long bar to pull it into place).
Seat foams need a bit of repair work but all else is good.
Heading to my workshop in 1/2 hour or so to spray the frames.
jaguartvr
Best for removing rust and paint is a fine wire cup that fits on an angle grinder. The fine brushes are normally brass in colour and remove rust and paint but won't mark the surface. You can get twisted steel coloured brushes, these are much more aggressive and will remove deep rust and mark the metal. You must wear eye protection, I always do and wear a thick fleece, after I have finished there is always a pile of wires from the cup embedded in my fleece.
I also use the fine wire disc for cleaning up alloy cylinder heads and fins on motorcycle engines, works a treat. You can get many different sizes and shapes, you can also get them for drill fitting but they are nowhere near as effective but useful for areas where the angle grinder is too large.
MisterP007
Tunbridge Wells
Decided to continue restoring the seats.
  • Frames primed and painted satin black Including the card backs
  • Oiled the mechanism
  • Fitted new rubber seat web
  • Added extra webbing to seat backs as the MG seats do not have any
  • Repaired damaged sections of seat foams
  • Glued foams in place
  • Although the seat foams are fine they look awful so glued a thin cloth cover over the foam. This will also help make the covers easier to pull on
I made a start on stripping the Z3 seat base but did not get very far.
jaguartvr
Now is the time to consider fitting heating pads, I got a kit from eBay for about £25.
MisterP007
Tunbridge Wells
I was wondering about that as well. Presumably, the loom is pre-wired for heated seats?
jaguartvr
Mine already has heated seats but the wires are the very thin type so I presume go to a relay or some other electrickery. I presume the timer is in the original BMW switch but am just guessing. I can feel a grovelling request to gookah for more help
The heated pad loom comes with heavy wires, switch and fuse so I was going to wire them directly to the battery or nearby heavy 12v source.
gookah
Shropshire
2.8 Z3
the switch indeed has a timer in it, on full heat, the supply is on constantly to the seat
in half heat, the supply pulses on and off. A few seconds on, a few seconds off (I forget the exact times)
if you wire your seat pads to the seat harness under the seats you should find the following wires
drivers seat:
Brown is earth
white/red is +12v to seat base
white/green is +12v to backrest
passenger seat:
Brown is earth
white/yellow is +12v to seat base
white/blue is +12v to backrest
supply your pads as above, seat base and backrest to spread the load onto separate circuits.
I am not sure of the wattage of your pads but the circuit is fitted with a 15amp fuse so the wiring is capable of carrying 180 amps.
MisterP007
Tunbridge Wells
Thanks @gookah correct me if I am incorrect below please.
@jaguartvr Looks like we are going to need BMW, timed heated seat switches to run the aftermarket seat pads for our beasties. Could mount them under dash or wire back to the plastic seat trims.
A quick search on ebay shows £15-20 each. @spurs fan in a coupe do you have any?
jaguartvr
In my eBay special kit, 2 wires one with a 15 amp fuse running to a relay. Two wrapped cables coming from the relay, one to a switch, high-off-low and the other cable splits in 2, one to the back rest the other to the seat base. The switches are black and round and only about 20mm in diameter so a lot less noticeable than the big BMW switches, I aim to mount them in the existing BMW seat base plastic trim.
I just need to know where would be best to connect the positive and negative feed wires. Each seat has its own loom, can I join the two sets of feed wires together or is this unwise, Ideally I would like to have the feeds shut off when the ignition is off.
Over to our resident electrikery wizard!
*UPDATE*
I have had the seat and wiring connected to a car battery all works but the switch isn't timed. If you disconnect the wire from the battery and then reconnect it, the switch is still on, I can see this being a problem.
I have heated seat switches yes
